  #24 (permalink)
Old 11-28-2012, 06:00 AM
bingo2's Avatar
bingo2 bingo2 is offline
Cobra Make, Engine: RUCC, SB 331 Stroker
Perhaps I'm missing something here but, this doesn't seem all that difficult to accomplish since you already have the plumbing from the manifold to the PCV valve.
Get a set of these: Weber 40 idf 44 idf 48 idf air cleaner, weber air, Dellorto air cleaner, 2 ½ in | eBay.
Tap into the underside of the air cleaner nearest your valve cover breather using one of these: Spectre Performance PCV Air Cleaner Smog Fittings 4960 - SummitRacing.com, you can get them at any auto parts store or another fitting with a 5/8" nipple end. I was able to find a 45* 3/8" NPT to 5/8" nipple at a local hydraulic fitting store.
Get one of these for the valve cover: CHROME MOPAR STYLE PUSH-IN BREATHER 1" STEM & 5/8" VENT | eBay, be certain this is a closed breather.
Be certain to use hose you use is certified for PCV use or you will fail. Some have gotten by using heater hose but, why take the chance.
This setup should satisfy the requirement for a closed PCV system and shown here:
