Then you will have to build a series 2 chassis a bit like Baz's but without the engine mount mods Baz had built to take the LS engine. Or a hybrid of the two.
The weight of the body is taken by the inner chassis rail alongside the tunnel, the flanges on the front inner guards bolt to the top rail and the rear of the body , inside the boot has two bolts each side which bolt to the rear chassis extension.
The under dash hoop also supports the body via three bolts into the hoop itself at the firewall inside the engine compartment and two bolts through the base of the under dash hoop into the top side rail on each side.
Hope I have described that so it can be understood.
