Old 12-03-2012, 11:42 AM
justcobra justcobra is offline
Cobra Make, Engine: Replica Motor Company
Thanks for the information.
At least you got my six photos and now we can communicate outside this forum if needed and it is confirmed that my RMC is a Series 2.
Construction of the chassis will be based on Baz's photographs with perhaps the exception of the modification performed to accommodate the LS1 which from all accounts was a torrid and expensive affair.
I will keep my lower stacker in line/pararel with the bottom edge of the sill avoiding th unsitely 25mm. overhang.
To avoid that problem I will take up the suggestion to modify the engine mounts ilo the chassis if a Corvette engine is to be fitted.
Fitting side pipes is perhaps period correct but is complex when it comes to Series 2 RMC. .
Fitting as standard underneath exhaust is perhaps the only to go to meet our engineering requirements and maintain reliability in engine management and performance,
