Old 12-06-2012, 08:06 AM
Wbulk's Avatar
Wbulk Wbulk is offline
Cobra Make, Engine: 66 Cobra
Default Caliper to Caliper Bracket Clearance
I am fixing some poorly designed caliper brackets for some GM metric calipers where the pads were hanging over the edge of the rotors. In the process that changes the clearance between the bracket and the caliper. See picture.
The picture is just for representation. The actual brackets are on the rear axle and are welded on. My intention is to add weld to that area and grind it to get the clearance correct.
On a long shot would anyone know what that clearance is supposed to be.
Wayne
"Everything is alive. If you get angry at a vehicle or the trans, it won't fix until you apologize and say you are sorry." "The vehicle always knows what it is doing and what the cause of it's bad feeling is. If you ask it humbly what the problem is, it will tell you. Then you and it will both be happy."
Gil Younger
