Old 12-06-2012, 09:37 PM
Cobra #3170 Cobra #3170 is offline
Default Dry Sump
Originally Posted by Morris View Post
That's right.....and the thickness of their scavenge sections are the reason for that.......a Cobra just doesn't have enough room for the size of their pump .... 4 scavenge sections and a pump section.....also the newer pumps are much more efficient then the older pumps..... On our Cobras ....their is barely enough room in the motor area....at least not in our FE configuration.
For what it's worth I am pulling 13" of vacuum on my 498" FE, I have a Dailey
Dry Sump with #16 lines to and from the tank. My valve covers are sealed
and the only vent is on the Stef's dry sump tank in the trunk. I have not really had any problems with this system and don't seem to have an oil vapor problem in the trunk. We tried it on the dyno with vented vs unvented valve covers and there was a difference of about 20 HP. What I really like is the engine compartment stays really clean compared to the times I had remote valve cover breathers with baffles etc. The only time oil gets out of this thing is when it is not running, then it leaks like an old Harley.
