Old 12-08-2012, 09:36 PM
Rwillia4's Avatar
Rwillia4 Rwillia4 is offline
Cobra Make, Engine: BDR #455, KC427W, TWM-FI
I have a TWM setup and you are right the individual stacks are connected under the fuel rails with tubing to a common plenum. The MAP sensor plummed from here. I don't have vacuum assist breaks (and I don't need it for this weight) but the engine is smooth and stable at idle so I think the common plenum works well. I run an XFI with MSD and haven't had any issues. The setup was pretty easy. Get a buddy you trust in the passenger to make f/a adjustments on the fly to smooth out the response through the rpm range under load.
