Old 12-09-2012, 12:34 PM
MRGEORGE077's Avatar
MRGEORGE077 MRGEORGE077 is offline
Cobra Make, Engine: Shelby American CSX 8000 Slab Side series, 289 High Pro , Eight Stack EFI system ,TKO500
But you can only use a semi-tubular rivet if part of the old holding pin is still sticking out. If you managed to break it off flush, then I think I'd just drill it out and use a Double Capped Screw Rivet in there -- you could put that in with your fingers and a little thread lock. That would be really easy to do. Personally, I always like to take the easy fix if possible. And if it's at least partially half-ass, that's all the better.
Ummm, even if it's not broke off it may be best to just drill it out and start over looks like there are plenty of the Double Screw Rivet at around.
Screwpost.com
Participating in a gun buy back program because
you think that criminals have too many guns
is like having yourself castrated because you
think your neighbors have too many kids.
