Old 12-09-2012, 02:46 PM
Wbulk's Avatar
Wbulk Wbulk is offline
Cobra Make, Engine: 66 Cobra
After looking at these closely the braking weight of the vehicle is supposed to be taken by the bracket rather than the caliper slide bolt. When the clearance exceeds the .012 the rubber bushings are compressed to the max and all the weight is then transfered directly to the bolt. In actuality the bolt is supposed to only keep the calipers centered and supply a guide for the calipers as the pads wear.
Before I fixed my rear welded on brackets the clearance was 3/16" and larger. Clearly mine were made way wrong.
Wayne
"Everything is alive. If you get angry at a vehicle or the trans, it won't fix until you apologize and say you are sorry." "The vehicle always knows what it is doing and what the cause of it's bad feeling is. If you ask it humbly what the problem is, it will tell you. Then you and it will both be happy."
Gil Younger
