Old 12-10-2012, 03:10 AM
RET_COP's Avatar
RET_COP RET_COP is offline
Cobra Make, Engine: Fordstroker 408w custom solid roller-Craft ported Brodix 17*heads-CFM ported Vic Jr. intake-1 3/4 primaries- 575hp-TKO-600RR Liberty upgrade- -Moser 8.8 trutrac-McLeod Street Extreme--QA-1-Wilwood brakes, Classic Chambered 3" Cobrapacks, Avon's
Hold on. Before you go ripping things apart, take the back of a screwdriver, (the one you are going to use to set the floats and adjust the idle) and tap the top of the needle and seat. {good taps) you are not going to break anything. Then try again. This usually loosens the needle from the seat. It could be debris but usually just a sticky ingredient in the gas that has dried. I've seen this alot in race cars that sit.
Lou
Lou
