In the end I decided to pull the axle and fix it out of the car, which turned out to be a good thing. B&B had sent me some tubing and some other small pieces. I decided to use some suspension tabs I had laying around which I believe gave it a lot more strength. While it was out I also fixed the caliper brackets as the bottom holes were drilled wrong causing the lowed edge of the brake pads to hang over the rotor about a 1/4", and I fixed the caliper to bracket clearance.
The axle is upside down
The holes had to be welded up re-drilled and tapped.
Wayne
"Everything is alive. If you get angry at a vehicle or the trans, it won't fix until you apologize and say you are sorry." "The vehicle always knows what it is doing and what the cause of it's bad feeling is. If you ask it humbly what the problem is, it will tell you. Then you and it will both be happy."
Gil Younger
Reason: Spelling
