Old 12-12-2012, 03:25 AM
PeterAllen's Avatar
PeterAllen PeterAllen is offline
Cobra Make, Engine: Puckett 250 GTO - LS1
Originally Posted by Gaz64 View Post
That actuating lever is normally tied to the diff centre on Commodore.
How does it work now, and do your brakes work correctly?
I'm not sure of the question? I'm not fitting the Ute sensor to the car, I was trying to explain that as far as I know passenger cars now have the proportioning valve in the M/C and it's probably best to fit an M/C without a valve (e.g. one from a Ute) and then install a stand-alone proportioning valve so you can easily balance the brakes to suit the weight distribution of your car.
I had removed the rear-end before I noticed the bias actuator (and took the photo) so I don't know where it contacted. I have a stand-alone Wilwood proportioning valve fitted but the car has not turned a wheel so I can't say how it works. Hope this explains a bit better.
