Old 12-15-2012, 03:48 PM
Wbulk's Avatar
Wbulk Wbulk is offline
Cobra Make, Engine: 66 Cobra
I finished fixing all four brackets on my B&B and I thought I might as well post how I did it in case someone else wants to fix theirs. I have seen pictures of others rear brackets that have the same to much clearance issue.
The key to doing this was to make a steel pattern. I measured with a 6" digital caliper the total thicknes on the caliper where the brackets sets. I then took some 1/8" steel strap and C clamped it against the caliper bracket mounting bolt holes and maked the holes with a transfer punch. I then found the center between the marked punch marks and layed out the caliper mounting points and squared them with the mounting holes. I then cut the area where the caliper would slid in a little smaller and then slowly ground it down until it would just fit over the caliper. I also drilled the holes that were marked for the guide bolt pins. The end result is you need the pattern to be able to just fit over the caliper with the pins going through the pattern and the caliper guide holes. Accuracy counts !
I built up the bracket ears with weld and ground down the sides flush. I then put two thicknesses of masking tape on each of the ears of the pattern and bolted it to the brackets. I then cut the weld with a thin cutting blade on a 4 1/4" grinder using the pattern as a guide. When I had just cut the masking tape I knew I was close. I then removed the pattern and tried to fit the caliper in the bracket. At this point I would just take a few light passes with the flat of the cutting blade disc and try the caliper by bolting it up and checking the clearnce with a feeler gauge until I got it within the .005-.012 clearance specified. I must say this was time consuming and took patience. I also found that the front S-10 calipers were not exactly the same thickness as the rear Cadillac calipers.
I hope this helps anyone else that wants to do this.
Wayne
"Everything is alive. If you get angry at a vehicle or the trans, it won't fix until you apologize and say you are sorry." "The vehicle always knows what it is doing and what the cause of it's bad feeling is. If you ask it humbly what the problem is, it will tell you. Then you and it will both be happy."
Gil Younger
