Old 12-17-2012, 04:48 AM
flaflier's Avatar
flaflier flaflier is offline
Cobra Make, Engine: ERA154 427 HR
Update:
I have redone the wiring, everything appears to work. I have physically replaced the distributor, and am now working on the wires.
Before I go to far, I need to connect the coil to the harness. My question is whether I need to jumper the ballast resistor, as my new setup (Petronix) doesn't need the resistor. I have the white wire (Coil +) hooked up, but with the ignition on, I am only getting .3V. I assume I either jumper the ballast resistor, or pull the +12 from the G/V wire of the ballast resistor and attach that to the + of the coil...
Thoughts?
Jim
