Old 12-17-2012, 08:43 AM
bobcowan's Avatar
bobcowan bobcowan is offline
Diesel oil doesn't have as much zinc in it as it used to; for the same reason gasoline oil doesn't. It still has more, just not as much as it used to.
15W-40 is kinda heavy for this time of year in my corner of the galaxy. Not sure what the weather is there, but I bet it's above 25*. I don't need 40 oil in my engine because of tight tolerances. But your builder should guide you what your engine needs.
For a new engine, I use the cheapest 5W-30 dino oil I can find, and 2 bottles of comp cams break in additive (11qt system). I run that for about 30-60 minutes, and 2-3 heat cycles in the garage. Then I drain and fill with the same thing, and drain after 2-3 gentle heat cycles on the street. Then I put in the good stuff.
As for watching what's going on - good luck with that. Even at idle things are moving so fast you really don't learn much. You'll learn more by using machinists dye and rotating the engine by hand.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
