Old 12-18-2012, 01:32 AM
Eljaro's Avatar
Eljaro Eljaro is offline
Cobra Make, Engine: Contemporary with 482 KC/SO, TKO600,IRS Jag/AMP, 3.54 Salisbury PL,
if the hub is 1/16 out of round you have to remove it from the bearings and have it put on a lathe and turn it true. The hub may have the bearings wrongly mounted also, because I can not imagine it being manufactured so badly. Maybe bearings are not seated right or the hub got hit and bent.
I had once an issue with the front axle stub, which had the wrong bearings and was actually moving inside.
Nothing sounds better than a Cobra in a Tunnel !
