Old 12-18-2012, 04:12 PM
Andrew429's Avatar
Andrew429 Andrew429 is offline
Cobra Make, Engine: G-Force MkII, Ford 429, Tremec TKO, Jag Suspension, Sequential LPG Injection, On The Road.
Hi JC,
The G-Force standard setup is as follows (if you want to go that way):
Sigma Booster (it's one of the smaller boosters available), XD/XE Master cylinder.
You can pick up both from a wrecker and Perth Brake Parts will recon them for you.
Tell them its for a cobra and needs more flow to the back brakes.
The sandwich plate (alloy plate between booster and firewall) can be cut down a bit to help fit the assembly into you wheel arch.
You may also need to "create" an access panel in the wheel arch.
Andrew
