Old 12-19-2012, 12:59 PM
gjkrv8's Avatar
gjkrv8 gjkrv8 is offline
Zedn, I had a similar problem and found that Mando's method resolved it, also I found the flare etc wasnt square to the AN fitting, once I squared it up it was ok. Those little leaks are hard to find as the fuel evaoprates pretty quicky on the very small leaks.
Good luck with getting the body back on - sounds like you are making great progress
cheers Gregg
