Old 12-21-2012, 10:32 AM
Three Peaks Three Peaks is offline
I have a set of Wilwood pedals and 2- 7/8" bore master cylinders I would like to sell. Never installed- I went a different direction with floor mount pedals. If you're interested, let me know in a PM or email.
Also, depending on what hydraulic clutch set up you use you may need as large as a 1" master for the clutch. I went through this and the 3/4" master that was recommended just wasn't enough. After going through the 7/8" master, I needed to go all the way to the 1" master to make it work. Pretty expensive lesson to learn.
Bob
