Old 12-21-2012, 08:10 PM
Dwight's Avatar
Dwight Dwight is offline
Smile
one company had a twenty year history of welding 9" hub on the rear end out of square. Some as much as 10 degrees. You did not have to measure it, you could see it was out.
I think their guy had a bad Friday every Friday or maybe it was Monday??
Some people think they can weld a hub on without an alignment bar and the bearing will "fix" the problem. NOT so.
Check and make sure your hub are perpendicular to the housing.
Dwight
