B&B Axle
The end result is this housing is bent. I leveled that car, and strung lines on it again with the same results. Just to make sure I checked it with toe plates and it has close to 1/4" total toe in. This thing has been a real pain. I just spent a few days fixing the coil over mounts that B&B made wrong. Then I fixed the caliper brackets that were also made wrong because the pads were hanging over the edge of the rotor, and this car hasn't even been on the road yet.
Does anyone know who can straighten a 9"?
Wayne
"Everything is alive. If you get angry at a vehicle or the trans, it won't fix until you apologize and say you are sorry." "The vehicle always knows what it is doing and what the cause of it's bad feeling is. If you ask it humbly what the problem is, it will tell you. Then you and it will both be happy."
Gil Younger
Reason: spelling
