Old 12-22-2012, 07:21 PM
sambo's Avatar
sambo sambo is offline
Originally Posted by gjkrv8 View Post
Paul. I was wondering whether it might be a faulty ignition barrel. Could you put a diode from the ACC lead from your switch to stop the "back feed" through the ACC circuit. I might be totally off track here but maybe your ACC circuit is getting a feed from somewhere else? Cheers Gregg
Hi Gregg. I fitted a brand new ignition barrel and switch because the original Ford Laser barrel was stuffed. I checked it earlier and all seems OK inside. I thought about fitting a diode or even a relay but I prefer to find the source of the problem rather than use a workaround. Thanks though - it might be my fallback position!
"A spectacularly fast car in a grand if dated tradition."
