Jerry, actually no. The area I welded was way on the end of the existing bracket, about 4" away from the tube. I think what happened is when I first got the car the metal guy for B&B welded the brackets for the four link way off so it had about 3 deg. negative pinion angle, pointing down. They took the axle back and cut everything off and redid all the brackets. When I got it back one axle would not slid in without force. I called them and told them about it. I should have just sent it back then. Monday I will call Currie and Strange and see what they say.
The area I welded.
Wayne
"Everything is alive. If you get angry at a vehicle or the trans, it won't fix until you apologize and say you are sorry." "The vehicle always knows what it is doing and what the cause of it's bad feeling is. If you ask it humbly what the problem is, it will tell you. Then you and it will both be happy."
Gil Younger
Reason: fixed sentence
