Old 12-29-2012, 09:27 AM
YerDugliness's Avatar
YerDugliness YerDugliness is offline
Cobra Make, Engine: Cobra Auto Works body, Ron Godell Racecars chassis, 1989 Mustang GT 5.0 HO (converted to carb), W/C T-5, 3.73's in a Ford 9" Traction-Loc.
I see you have a PCV running to the back plate of the intake manifold from your brake booster port on the carb; that's good. But I see that on the driver's side valve cover you have a cap that does not allow breathing. Is your breather over on the passenger side valve cover? (Which I can not see). You have to have some place for the air to be drawn in.
Patrick, help me out here. It was always my understanding that the PCV (Positive Crankcase Ventilation) valve was designed to vent pressure from inside the engine that was a result of combustion gasses bypassing the rings, a common and unavoidable process. I was unaware that any form of fresh air intake was necessary...in fact, as I understand it, the PVC system requires pressure in the crankcase and a vent could prohibit pressure from building.
Please set me straight on the function of the PVC valve/system....
Thanks!
Cheers!
Dugly
YD,E./PNB
No names were changed to protect the innocent!
