Old 12-29-2012, 10:53 AM
rpatton3's Avatar
rpatton3 rpatton3 is offline
Cobra Make, Engine: Backdraft 874 solid red Roush 427 small block 515 hp
Default TKO and T56
Originally Posted by Roush #1 View Post
Russ,
Your comment comes up frequently, and the only answer I have is the gear ratio differences between the T56 and the TKO along with my lower rear gear ratio. Compare the T56 to the TKO and you will see a little lower ratio (normally) in the T56 vs the TKO in the first three gears and a closer ratio (normally) between 4th and fifth in the T56 vs the TKO which all contribute to a little quicker acceleration through the first 5 gears.
If we were both running the same overall gear ratio, I doubt there would be much difference in acceleration with both of our engines coming off the same dyno making very similar horsepower and torque numbers.
This information is what I believe the initial thread question was about. I hope we have helped answer the question.....although my combination works for our horsepower and torque curves it probably wouldn't work as well with another engine.
Thanks for the enlightenment . I have volumes to learn and I bought a new turnkey car on birthday 58 and promptlly spent a year in and out of hospital and home IV's.
Seriously, I don't think I would ever have the stones for 167 MPH in passenger's seat with a professional driver at the wheel. The BMW rear axle is not up to drag racing, either. You have done your homework well.
Right now, I am getting big mufflers to pass "tennis ball" test.' Spirited street driving is all my car will ever see. The road race/rally in Big Bend and Silver State? would be at top of my "Bucket List."
Have a great 2013. Thanks again.
Russell
There were no atheists in the foxholes.
