Old 12-31-2012, 05:16 AM
Jethrow's Avatar
Jethrow Jethrow is offline
Cobra Make, Engine: FFR Mk4 Roadster, LS3, TR6060, 8 3/4"
Default Fuel Lines
Next up, fuel system.
After a false start with the wrong pump being purchased (anyone need a never been used Holley pump? Not used because it requires a bottom outlet from the fuel tank and my tank is a top outlet) I ended up getting a Walpro intank unit.
I also went with larger fuel lines than supplied in the kit going to 3/8 from 5/16 feed lines.
I did keep the Holley fuel pressure regulator however.
Third line above is for the charcoal cannister - I plan on using one from a VS Commodore.
Tim
FFR Mk4 Roadster
HSV Clubsport R8
