Old 01-02-2013, 12:33 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by vector1 View Post
so if the pump is below or at the bottom of the tank, does the portion of fuel in the line coming out of the tank drop back into the tank?
my point is the fluid doesn't know where the pump is, as long as there is no air leak, the siphon is maintained.
Yes, that would true to a point, but if the pump is higher than the level in the tank some of the fuel would still run back to the tank.
Better off with the pump at the bottom of the tank.
Gary
