  #46 (permalink)
Old 01-03-2013, 09:32 PM
justcobra justcobra is offline
Cobra Make, Engine: Replica Motor Company
Originally Posted by Tenrocca View Post
Stephen,
Heres a pic of series 1 arms, you can see the difference when the front arm is at the back and back at the front as Ive layed the left hand side on top of the right hand side:
Heres the series 2\3 arms I have:
See how they kink in a bit just after the pivot bolt thingy (technical term). The difference between using series 2\3 arms (which are the same dimensions front and back) and the series 1 arms, is that the series 1 arms will place the upper ball joint 8.5mm further back.
The jury is out on whether series 2\3 arms come in a "straight" design, the place I got mine from said that they had not seen series 2\3 arms straight like series 1.
Cheers.
Gentleman! I need more photos of Series 3 RMC front end showing amongst other things how the Jaguar upper and lower wishbones are adapted th the chassis as I am constructing a hybrid chassis.
I got three Jaguars -two with a V12 which have LSD and the third is S2 six cyclinder.
