Old 01-05-2013, 03:05 AM
byroncobra's Avatar
byroncobra byroncobra is offline
yeah i did that geof, but early in the build but this problem is recent.
Gaz got me thinking, re the actuating rod on the booster. Mine doesn't have an external adjustment just a bolt that screws through the pedal bracket to adjust the freeplay and brakelight switch. Perhaps it's moved in, shortening the pedal throw and thus actuating the brake. Anyway, I've adjusted it ready to test......
however I now need to bleed the brakes after cracking them earlier and i won't have a helper till tomorrow so watch this space......
Jim, no recent pad change, it was during the trackwork at the Nationals that I first noticed the heat and i just put it down to heavy braking, but it's all the time now.
It's a Ford XD single piston MC, no obvious freeplay that you mention. If the test tomorrow fails I'll try your suggestion to crack the front brake line
Thanks Fellas
