Old 01-06-2013, 04:40 AM
rsk289's Avatar
rsk289 rsk289 is offline
Cobra Make, Engine: 289 leafspring, r/p
Default Leaf spring 289 wiper motor mount
Can anyone tell me how the wiper motor (DR3) was mounted to the top of the LH footbox? I know XK Jags which used a similar motor had a metal plate fixed to the body to which the motor was mounted using the usual three hex-shaft bolts with rubber insulators.
For the Cobra, was the footbox simply drilled big enough to take the same rubber insulators? It seems too thick for this, but I guess there's every chance the motor was simply bolted to the top of the footbox without any rubber insulators.
