Old 01-07-2013, 03:27 PM
FatBoy's Avatar
FatBoy FatBoy is offline
Cobra Make, Engine: Kirkham #523, 427 S/O
Hi Kev,
Why didn't you simply make the throttle linkage pivot rod longer so that it reached the other side of the carb? That way you cold keep the cab the right way round and pull the throttle rather than having to push it.
I've just fitted a thermal spacer between my carb and manifold because I was getting heat soak in traffic in hot weather. I've had a custom filter made up by ITG to overcome the space limitations.
Paul
