Old 01-08-2013, 02:02 AM
kdavies3 kdavies3 is offline
Cobra Make, Engine: Dax Tojeiro, 450bhp 383 ci Stroker, Tremec TKO and Contemporary CCX, Big Block Ford, old school.
You may be right about the rose joints I guess, but I think I have the linkage set up so that I'm pulling the carb open not pushing.
So as long as the carb being the other way around doesn't matter I think I'm OK as I am, I was going to put a PCV in the valve cover on one side (left) and keep the breather on the other (right).
I think I may fit a phenolic spacer for good measure anyway.
On a different issue can you remember if you needed to restrict your steering rack travel on your CCX to stop tyre rub on lock on the on the inside?
Kev Davies, Wales (UK)
CCX-3-4028.
445 ci Ford FE
