Old 01-08-2013, 11:49 AM
Bernica's Avatar
Bernica Bernica is offline
Senior CC Premier Member
This may be your answer. The baseplate is custom made for a 9" filter and will fit inside a turkey pan. Sits flat on the carb, while giving you access to the float bowls. AND gives you the max hood clearance. Also allows you to use the Extreme filter tops for more air. I am using the Quik-Latch on the top, which we modified for a clean flush look. See Mickmate for one. Already on many cars with no complaints......
I should add that the package includes the custom baseplate, K&N filter element (2-1/2" tall std), and the K&N Extreme top (modified) with complete Quik-Latch assembly. All ready to go.
Just wanted to let you know what's out there......
