Thread: Power Steering
Old 01-21-2013, 05:15 PM
rpatton3's Avatar
rpatton3 rpatton3 is offline
Cobra Make, Engine: Backdraft 874 solid red Roush 427 small block 515 hp
Default Rotary table
The rotary table is the trick for cutting radius. I would usually just clamp the piece to the rotary table with the center of the diameter I want to cut (ie the center of the bolt hole) at the center of the table. For the large inside radius I cut that with the boring head and only cut an arc of the circle. I can change the radius by changing the diameter of the boring head.
On this piece I cheated for the small radius around the bolt holes and did them on the belt finisher.
My Rotary table is where I have lunch every Tuesday at Rotary Club of Jonesboro, Arkansas. District 6150 and Club 2520 (jonesbororotary.org)
I have 27+ years perfect attendance. If anybody drives their Cobra to our meeting, I will buy your lunch.
I know that is not you used and you do great work! I am impressed.
There were no atheists in the foxholes.
