Old 01-22-2013, 04:31 AM
patrickt patrickt is offline
Default What I Would Do...
Remove the wires from your ignition switch. If the ignition & parking lights still stay on, you have a mis-wire elsewhere; backtrack the circuit to find the origin of the feed. If the lights go out, measure the continuity across the poles of the ignition switch to confirm it is indeed a bad switch. A faulty ignition switch is not uncommon.
