Old 01-22-2013, 05:14 AM
DanEC's Avatar
DanEC DanEC is offline
Remove the wires from your ignition switch. If the ignition & parking lights still stay on, you have a mis-wire elsewhere; backtrack the circuit to find the origin of the feed. If the lights go out, measure the continuity across the poles of the ignition switch to confirm it is indeed a bad switch. A faulty ignition switch is not uncommon.
I can try removing the wires from the ignition switch. I need to double check the connections on the light switch too, although I doubt something crossed there would cause the ignition light to come on also. I suspect there is something in common with the two.
