Old 01-22-2013, 05:34 AM
strictlypersonl strictlypersonl is offline
1. With battery hooked up but key off - the ignition light is on and the tail and parking lights are on. There is a slgiht discharge showing on the amp gage.
As was said before, check the connections at the ignition switch. Also the connections at the head/park switch.
2. No turn signals
Could be many things, including low voltage. Let's get the rest of the stuff out of the way first.
3. Heater runs full time with key in accessory or ignition position. I switched the leads on the switch without any change. I suspect the switch is bad.
Probably
4. No brake lights (possibly because the master cylinder doesn't have any fluid in it?)
The switch is hydraulic. No pressure, no electricity.
5. Headlights, horn, wipers, dash lights and engine fan all seem OK. I didn't try spinning the starter since I had these other problems.
6. the right front park light would not light up at first. It had power to it but there isn't a ground in the harness for the housing. The black wire in the harness turns and runs to the headlight run and back up to the engine compartment. I ran a ground from the housing to the left light housing and it lit up. I don't know if that will interfere with the turn signals or not - I don't think so???
Something weird here. I don't ever remember ever sharing the parking light ground with the headlight ground. Just not the way I build the harnesses. Both grounds end up connected at the crossmember connection. But a separate wire will work
I double checks the wiring on the ignition switch and starter relay and everything is OK according to the manual and wiring diagram. I was careful wiring everything up. The ignition light/parking lights on with the key off is the issue of most concern immediately.
The headlight switch is powered whether the ignition is on or off, so there's something awry at/with the light switch. The other possibility may be a couple of wires switched at one of the multi-pin connectors. I'll have to dive into that possibility this morning. You might check yours yourself: The wire colors on each side must match. Any wires with stripes are at the corner of the plug to make them easier to identify.
