Thread: Power Steering
Old 01-22-2013, 04:41 PM
Aussie Mike's Avatar
Aussie Mike Aussie Mike is offline
Originally Posted by sambo View Post
Hey Mike, I've fitted a VK power rack with the teflon braided hose as well, seems to work well. The fittings on my rack look much the same as your picture above with the black male-to-male connectors - not sure what you mean by bump tube fittings?
Hi Paul,
Bump tube is sometimes called beaded tube. The end of the tube has been pressed in a die to form a ridge around it. This is what the O ring sits up against to make the seal. The bump or ridge also gives something for the retaining nut to run up against to keep the fitting in place.
Mike Murphy
Melbourne Australia
