Thread: Fast efi
Old 01-24-2013, 07:04 PM
bobcowan's Avatar
bobcowan bobcowan is offline
Originally Posted by sideshow View Post
The reason u need to have a modded dizzy is the ford dizzys only have a crank signal
And some u need a cam signal too
Ford dizzys don't have the crank and cam signal in the dizzy
Some Ford Explorer's were equipped with a 302/5.0 motor with EFI. It had a distributerless ignition system. Instead of a distributer, it had a cam/crank signal generater. It's an easy drop in to a 302 windsor engine. It can also be used in a 351W, if you change the oil pump and drive shaft.
You can also buy an aftermarket sensor from AEM. It'snot cheap, though.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
