But when it's distributerless it normally has a 58 tooth reluctor wheel on front crank harmonic balancer just like the au v8s. When running std ecus
So if the ecu can handle this setup then its fine
I recently did a Haltech on a big 351 motor with Morrison 8 throttle body injection
With 8 ls1 coils
We ran a 12 tooth reluctor on Front of motor because we can with a Haltech
And an au style single pulse cam sensor which runs of the dizzy
This was because we had to have a small cam sensor to fit under the manifold
And to get a good right angle drive setup for a dizzy with leads would have been
Priced in the 3 to 5 thousand depending if we wanted cheap or good quality
