  #35 (permalink)
Old 01-26-2013, 09:49 AM
undy's Avatar
undy undy is offline
Originally Posted by tcrist View Post
I would think that temps are still temps? Isn't 180° still 180° no matter what you are running for coolant? Why would the internal temps be any different?
Also, would running Evans eliminate having to run an anode because of electrolysis (sp) from using an aluminum radiator?
I should have been a bit more explicit...
Evan's fine, assuming you have a bit of cooling system redundancy. My point was, if you have a cooling system that doesn't cut the mustard now and temps rise above the norm then replacing the coolant with Evans will make the situation worse. You've now cut your ability to reject heat even more.
Too many toys?? never!
