Old 01-26-2013, 05:55 PM
patrickt patrickt is offline
Originally Posted by Exhelojocky View Post
Patrick, if you a few minutes, can you explain "lift-throttle over steer" on these cars, and if there is any compatible car that has the same responses...
Lift Throttle Over Steer is when you go in to a corner, you think you're going a little too fast, so you lift your foot off the throttle, and maybe even, God-forbid, touch your brakes, and the weight of the car transfers to the front wheels and off the rear wheels. The lessening of adhesion on the rear wheels results in the rear "breaking loose" and coming around on the car. Because the wheel base of the Cobra is so short, you have a very short radius to your circle, which means this happens very, very fast. If you've ever seen a car, off the road, on the inside of a curve, completely turned around so it's pointing at you, that's what happened.
