Old 01-28-2013, 06:18 PM
63mercury's Avatar
63mercury 63mercury is offline
Cobra Make, Engine: Scratch building frame,FFR Mkll body ,302w, and T5 trans, 3.0 rear.
Just about done mounting the radiator, 2 lower brackets to weld and 2 upper brackets to drill and bolt in. Upper hose assy is done lower has parts on the way from Speedway Motors. Footboxes are progressing slowly, trans tunnel is also coming along, next step is to transfer patterns to 16ga steel sheet metal. The trunk area will be my next challange. Pics will follow shortly.
1963 Mercury Monterey 460+ .060 .//Cobra clone, Scratch build frame /302/ T-5 WC / 3.00-9in/FFR mkll body (Broken but repairable) /91 Lincoln Wire Wheels // : N.S.M.C Charter/Life Member// Die Hard Blue Oval Nut
The finish is better than the beginning. Ecc7:8
