Originally Posted by ERA2076
Have not talked to the builder yet - gathering info so I can intelligently talk to him. Appreciate the input.
chr
Yep, that's the best approach.
You're going to want a mix of the two cams that you listed. The 222/224 cam won't get you to 7000, but I would consider it more correct on the duration split. The 242/248 cam has a bit more duration than you need, and I think it would have too much overlap for the Webers. The LSA is correct for both cams, 112-114 is usually the sweet spot.
Lift should match the capability of the cylinder heads.
Comp has a myriad of solid roller or solid flat tappet lobes to get you anywhere you want to be.
