Old 02-02-2013, 02:27 PM
Bill D's Avatar
Bill D Bill D is offline
Cobra Make, Engine: FFR chassis and suspension, Mr. Bruce 289 FIA body
You can see in Jeff's second picture it has the heat shield mounted on the inside. The exhaust drops down between that and the motor.
I'll be running side exhaust. Would the pipes run under the battery? Should I use some type of heat insulation?
