Old 02-07-2013, 09:37 PM
T.L. T.L. is offline
Cobra Make, Engine: Harrison build #98 with Supercharged 6.2L of Chev Power, TKO600 5 speed gearbox
I put the car 2ft in the air today and took the wheels off.
Found I have 275lb springs all around the car, and also a big petrol leak!!. Leak fixed and while I was there I would the R down a bit and the C up a bit. Still need longer springs as there is about 4" of thread showing underneath the spring and at some stage in the compression of a spring, it looses its ability to do it's job correctly.
Might head for some 14" 300lb on the front, the rears might stay at 275 but move to 12", so I need to move the fronts onto the rears and get a new set for the fronts.
Also gave me an opportunity to have a look for any loose bolts and put some locking wire onto the knock ones.
