Old 02-08-2013, 01:50 PM
T.L. T.L. is offline
Cobra Make, Engine: Harrison build #98 with Supercharged 6.2L of Chev Power, TKO600 5 speed gearbox
Originally Posted by muzzza View Post
TL There are a swag of reasons why you should never have the same spring rates front and rear. Spring length does not change ride height. If you wish to raise the car, you can use stiffer springs, longer shocks, or lower your upper spring mounts. Crazy amounts of spring pre-load is not an option. QA1 make 1" and 2" shock extensions as an alternative to purchasing longer shocks.
I am using 17" QA1 DD shocks and 10" springs on the rear of my car and 15" QA1 DD shocks and 10" springs at the front. I have also dropped front upper spring mounts about 10mm giving about 15mm extra height at wheel ( 18" rim )
Thanks for that information.
At the moment I have 'crazy amounts of spring pre-load' so want to reduce that way back. I'll have to dig out the paperwork on what length shocks they are.
Car seemed to take the road bumps a bit better with the new settings, just need more time on the roads.
Found out that the ABS didn't work so I'll need to look into that as well.
