Old 02-10-2013, 05:57 AM
patrickt patrickt is offline
I can't be sure. I was checking the oil pressure and ammeter gages but I don't remember noticing if the ignition light was on. It's not easy to see standing outside the car. I'll check it when I get the coolant system sealed back up and can re-fire it.
Usually that light jumps right out at you. If you're really lucky, the light is not on when running and you just have your ammeter leads reversed, so you really have a slight charge, which is normal, and you just think you have a discharge. That's if you're really lucky.... Keep us posted.
