Old 02-12-2013, 05:31 AM
patrickt patrickt is offline
My horns blow but one side of my turn signals don't work. I noticed a section in Bob's manual on that so I'll start there.
Just trace the circuit back, starting at the "turn switch" side of the trailer relay, which is fastened to your steering column just over your knees. The only trick to that if the front turn signal bulb is bad (like with a blown filament), or if the circuit is "open" up there because of a broken wire or bad connection, then the entire side can fail to light up. The wiring is very simple, though; it's not nearly as complicated as today's cars.
