Old 02-12-2013, 08:48 AM
patrickt patrickt is offline
Originally Posted by lippy View Post
Is insulating on the outside only adequate for the footwells, or does it still get warm inside and possibly require insulation I side as well?
I do not believe you need to put any insulation on the inside of the car. I don't believe you need to put any insulation on the tunnel, either inside or outside -- the tunnel is easy enough to pull if you want to do it later, for some reason, but I don't think you ever will. And I really don't believe you need anything, ever at all, other than carpeting, in your trunk area. Don is right about the extra venting and heat shields -- I have that and it does, indeed, make a difference.
