Old 02-13-2013, 04:33 AM
sambo's Avatar
sambo sambo is offline
Well I fixed the above issue tonight so I'm finally able to stand the rear wheels up with about -0.5 deg camber and the 275s now tuck up nicely inside the guards thanks to narrower track (roughly 10mm each side). It was a bit of an investment fitting adjustable arms all round but it allows you to remove just about all of the preload on the QA1s. I lowered the rear another 8mm, compression set to 3 and rebound to 6 and I now reckon 250lb springs are spot on with the R33 rear end.
"A spectacularly fast car in a grand if dated tradition."
